Lookout
Logging an ASCII signal to Excel through Lookout
The ascii2 is the one for length. Ascii1 is for the weight.
Message 31 of 35
(3,061 Views)
Ok. I will try this first thing tomorrow morning when I can get back to the PC out on the line. I hope it works!
Thanks again
Message 32 of 35
(3,057 Views)
Well Mike,
I set the ascii2 response format to "M%f" and it accepted the connection. Then I made the display show the value of ascii2.RSV1 instead of ascii2.response. The first signal recieved shows a 3.00 and then it stays at that value even though more signals should be coming in. (Quick note: I am measuring the length of pipe which are all in the range of 30 feet, so I'm not sure if it is stopping at the first digit and actually updating to the next signal or not. They will all start with 3x.xx) It logs the same- a 3 in every cell. Does this tell you anything?
Thanks again.
Message 33 of 35
(3,046 Views)
What is the meaning of the "M%f" designation? Are there other response formats like this that yield a different response? Is there a table of these formats somewhere? I couldn't find anything on the Lookout help file.
Thanks.
Message 34 of 35
(3,026 Views)
Open ascii driver properties, click Help.
ASCII Object Response Format Examples
Forshock - Consult.Develop.Solve.
Message 35 of 35
(3,000 Views)
