Lookout
Lookout 3.8 compiler error ' Inappropriate parameter type ('Null')
Inappropriate parameter type "Null" is the error message, it is generated
in a datatable alias after compiling but it does not show up in the exact
same code in another process file ! Any information would help???
e-mail me @ fred.turner@brightstar.com
(3,992 Views)
"Fred Turner" wrote:
>Inappropriate parameter type "Null" is the error message, it is generated>in
a datatable alias after compiling but it does not show up in the exact>same
code in another process file ! Any information would help??? >e-mail me
Hi Fred,
In Lookout 3.8 was introduced the SQL commands to query an ODBC compliant
database. This error happens whenever you install Lookout without the ODBC
driver. Please install that and Lookout should compile properly.
Good luck
CARLOS
(3,992 Views)
