Lookout
Web Client Refresh
When using a web client, everything works fine the first time in. If I use
the "refresh" button or "back" button and then try to load any web client
I end up with a blank screen. The "need to load files" dialog comes up,
the files download and then dies. If I close IE, and start over, it works,
once.
I've talked to NI but they can not duplicate the problem, but they think
the problem is in an IE or Windows setting. I tried the web demo on the
NI site and had the same problem. I have tried files on various computers
with Win95, Win98, NT IE4 and IE5. I even tried to unload all of Lookout
and IE and then reloading IE with all the defaults. The same problem occurs
on all.
Microsoft's site mentioned a way to review the error log files w
hen active
x clients fail to load. No errors there.
Has anyone seen this problem?
(3,757 Views)
Jim,
Are you using Lookout 4.0 or Lookout 4.0.1? There is a known problem with
Lookout 4.0 that could possbily manifest itself as what you describe. (It's
process-dependent though, so it might not misbehave in every process.) The
problem was not with the ActiveX side of things at all, but with Lookout
itself. When you hit the refresh button, you are essentially telling Lookout
to shutdown completely and then restart immediately. In a multithreaded
application this can sometimes cause trouble if some of the threads from
the old run are still around when the new run starts. In Lookout 4.0.1 we
made sure that all of these threads are gone and that Lookout starts clean.
Ross Houston
Lookout R&D
use>the "refresh" button or "back" button and then try to load any web client>I
end up with a blank screen. The "need to load files" dialog comes up,>the
files download and then dies. If I close IE, and start over, it works,>once.>>I've
talked to NI but they can not duplicate the problem, but they think>the problem
is in an IE or Windows setting. I tried the web demo on the>NI site and
had the same problem. I have tried files on various computers>with Win95,
Win98, NT IE4 and IE5. I even tried to unload all of Lookout>and IE and then
reloading IE with all the defaults. The same problem occurs>on all. >>Microsoft's
site mentioned a way to review the error log files when active>x clients
fail to load. No errors there.>>Has anyone seen this problem?>
(3,757 Views)
I am using Lookout 4.0.1 B51. In the mean time, I did find a machine that
everything works on, running NT 4, B1381 SP3. I have noticed that sometimes
when I shut down a process under IE, it will hang after the window has closed
and I have to use task manager to kill it (related?).
Jim
"Ross Houston" wrote:
>>Jim,>>Are you using Lookout 4.0 or Lookout 4.0.1? There is a known problem
with>Lookout 4.0 that could possbily manifest itself as what you describe.
(It's>process-dependent though, so it might not misbehave in every process.)
The>problem was not with the ActiveX side of things at all, but with Lookout>itself.
When you hit the refresh button, you are essentially telling Lookout>to
start immediately. In a multithreaded>application
this can sometimes cause trouble if some of the threads from>the old run
are still around when the new run starts. In Lookout 4.0.1 we>made sure
that all of these threads are gone and that Lookout starts clean.>>Ross Houston>Lookout
R&D>>"Jim Mauldin" wrote:>>>When using a web
client, everything works fine the first time in. If I>use>the "refresh"
button or "back" button and then try to load any web client>I>end up with
a blank screen. The "need to load files" dialog comes up,>the>files download
and then dies. If I close IE, and start over, it works,>once.>>I've>talked
to NI but they can not duplicate the problem, but they think>the problem>is
in an IE or Windows setting. I tried the web demo on the>NI site and>had
the same problem. I have tried files on various computers>with Win95,>Win98,
NT IE4 and IE5. I even tried to unload all of Lookout>and IE and then>reloading
me problem occurs>on all. >>Microsoft's>site
mentioned a way to review the error log files when active>x clients>fail
(3,757 Views)
