Lookout
Lookout 4.5.1 and Citadel Not Logging
I am running Lookout 4.5.1.  It had stopped logging data and the trends are empty.  I was getting Citadel Logging buffer is full for the individual objects.  I had shutdown Lookout and logged into the PC as administrator to look at the MSConfig file to verified that Citadel is set to start up.  Then I stared Lookout.  The process started and is reading data fine.  There are no more Citadel logging buffer full alarms, but there is still no logging going on.  I even cleaned out the database file where the data is saved.  The lighthouse in the task bar says that Citadel is running.  I have tried stopping and restarting it with no success.
Message 1 of 1
(5,770 Views)
