Lookout
Lookout 6.1 build 27 OPCClient does not launch the Opto 22 OPC SEVER
As I wrote, I have resolved the problem by not using Lookout 6.1 long ago.
Opto 22 software used, has OPC 2.0, it has to be set as that.
Fortunately, the IT department here is still using XP everywhere in the company, there is no need to migrate to Lookout 6.1
Thanks anyways.
Message 11 of 14
(2,124 Views)
Hi ryan;
The error is running lookout 6.1 and the opto22 server.,which i presume is vers 1.0,2.0 compliant. running 3.8 and the server works no problem on vers 1.0 opc tags.
Message 12 of 14
(2,124 Views)
Hi ;
I assume you are saying there is issues with Xp and lookout 6.1 (including problems with connection to the opto22 server) and that version 6.0 is a better bet for that particular windows version.
thanks.
Message 13 of 14
(2,122 Views)
Yes, there are problems with Windows XP Profesional (corporate) and the dababase of Lookout 6.1. I had them in several PCs.
Message 14 of 14
(2,105 Views)
