Lookout
Lookout Client wont go into EDIT mode
I have developed a server process and then created a client copy from it. When I loaded it on the client computer, I cant troubleshoot it beacuse I cant get into EDIT mode.
What am I missing?
(3,543 Views)
There are two possibilities:
* What kind of license do you have in client machine? You have to have a development one, or...
* it's a matter of users and permissions. If you have set some restrictions for editing, make sure you have same users and permissions level on both computers.
Hope it helps,
JPSS
(3,537 Views)
I have the same issue, my client computer will not go into edit mode. I installed only the Client portion of the software maybe thats the problem? I built a switch from the tutorial on the server and copied it to the client and that seemed to go well, the next part of the exercise is to remove the red X but you have to get into the edit mode on the client machine. What do you think?
(3,110 Views)
