Lookout
Lookout OPC Server Name
A NI tech note states to use  NationInstruments.LookOutOPCServer  as the OPC server name.  Is this correct ?  When launching Lookout out of the box,  does this OPC Server also launch, or does one need to configre separately
(5,782 Views)
Actually this OPC Server is always there. It is registered, and you can connect it even if you don't launch Lookout. This OPC Server exports all the items in running lookout process.
Message Edited by Ryan.S on 03-11-2010 03:56 AM
Ryan Shi
(5,773 Views)
