Lookout
Lookout SQL Server Running at 100%
Hi there,
We have a system that is logging alarms for several sewage pumpstations.  We recently had a problem with the HMI machine where the Microsoft SQL Server was running at close to 100%.  I was unsure what SQL server was doing, so I disabled it in the services manager.
However, after doing this I found that I could not search the database for alarms (which makes sense).  I then restarted the SQL Server, but once again found that it pushed the computer CPU close to 100%.
Is there any reason for this?  How could this be fixed?
-andrew
(3,923 Views)
Check this previous post.
http://forums.ni.com/ni/board/message?board.id=190&message.id=3160
(3,915 Views)
