Lookout
Lookout Web Client capability and Admin Password reset
From the Lookout Web Client setup directions:
" * For your web client to connect to a server process, you need a Concurrent Client License registered on the server machine"
I currently have 4 client licences installed and am only using 1.  When I go to the file menu the "Web Server Export Options" is grayed out and inaccessible.
I think this could be due to not being logged in as administrator to the Lookout Server.
This leads to another problem -->  Is there a way to reset the administrator password?...as I have forgotten/lost it.
(6,165 Views)
Problem solved.
Refer to the following post for solution.
http://forums.ni.com/ni/board/message?board.id=190&message.id=2256&query.id=153417#M2256
Message Edited by jvance on 04-29-2008 02:34 PM
(6,164 Views)
