Lookout
Lookout opc or link problems
I am using Lookout 6.0.2 on a new Win XP desktop.  The Lookout OPC client object is used for communications via Rockwell Software RSLinx's (Professional Rev 2.43.01.23) OPC server to ControlLogix PLC's over ethernet.  In other words, the Lookout communicates with RSLinx by OPC, and the RSLinx communicates with PLC's by ControlNet.
We have 3 Lookout processes, one which is the "server" process, and contains the OPC Client object. The other 2 process files are "client" processes, and reference the OPC Client object  by symbolic link.
We have many Lookout switches in the "client" processes, that are remoted to a tag in the ControlLogix PLC using symbolic link. A typical link for a remoted switch is:
..\..\[Link_to_Drivers]\OPCclient1.PLC_12.Online.SWITCH_TAGNAME
OR   IF USING ABSOLUTE REFERENCE:   \\ComputerName\ProcessName\[Link_to_Drivers]\OPCclient1.PLC_12.Online.SWITCH_TAGNAME
In this  way, the Lookout switch object has a read/write link.
The problem is this:  Periodically the write link will stop working.  When this happens, all the Lookout switches and even the Lookout pots will lose ability to write to PLC, but the read links are still working. We can read the data and the switch positions, but the changing setpoints with the pots and operating equipment with the switches is then impossible.  This "lock up" can be fixed by closing down all the Lookout processes (but not Lookout), and then restarting the Lookout processes.
This problem is intermittant and not repeatable.  Does anyone have idea how to troubleshoot this problem, or have an way to isolate and fix this problem? Thanks!
(5,038 Views)
This problem is fixed by lookout 6.0.2 updates. It can be downloaded from http://joule.ni.com/nidu/cds/view/p/id/506/lang/en
You need first to login MyNI, and then download lo602_updates.zip. Unzip it and copy all files to lookout folder.
This update is applied to Lookout 6.0.2 server system. You don't need to copy these files to client system.
Ryan Shi
(5,014 Views)
