Lookout
Unabe to change settings in revise modbus secondary
I am changing the serial port from com1 to com4 in "REvise Modbus Secondary", after i change it and do a save, i reopen lookout and the com port has changed back to com1.  I am running lookout 6.1
(5,096 Views)
What if you modify other parameters?
Open the .lks file by notepad. Check if COM1 is changed to COM4.
The code for modbus object looks like
Modbus1 = new Modbus (1, "COM4", 9600, "none", 8, 1, , 2000, 2000, 125, 125, 800, 100, 8, 4, 4, 500, true, false, , , 0, , false);
Ryan Shi
(5,077 Views)
