Lookout
Lookout talking to two Modbus devices
I have two devices on Modbus RS485.  I have both on a Serial to Ethernet converter, and the Ethernet converter on the same network as my PC.  Each device is set up in Lookout as a Modbus Ethernet device, using the IP address of the converter - differentiated by having a different Identifier matching the Modbus address of each device.  Does this sound like a good set up as far as Lookout is concerned?
The problem that I am having is that only one device responds to the queries sent by Lookout, so my question is part of troubleshooting why it's not working.
(5,799 Views)
This sounds about right.
Example:
Lookout (10.0.0.1)
Site 1 (10.0.0.10, Serial-to-ethernet MB gateway)
PLC 1 (ID 10)
PLC 2 (ID11)
Site 2 (10.0.0.11, Native MB TCP, ID 1)
PLC 3
Site 3 (10.0.0.12, MB Gateway)
PLC 4 (ID 10)
Forshock - Consult.Develop.Solve.
(5,782 Views)
The RS485 terminating resistor setup?  Usually required for daisy chaining.
(5,781 Views)
