Lookout
Write single coil issue with logical OneShot
Hello, this would seem to be a very simple problem, however they all are until you find the last answer.  We have a remote switch (Zetron) that has two write coils 1=open 2=close.  In Lookout, I have a two pushbuttons that each trigger separate OneShots that direct the Modbus output.  For example:
Modbus5.1     = OPEN_US192_OS;
Modbus5.2     = CLOSE_US192_OS;
What I see from the com trace is that Lookout writes the coil, but with zero, wereas I need it to write a one, or true.
08:02:38.5 - Modbus5 -> [40][05][00][01][00][00][93][1B]
08:02:41.0 - Modbus5 <- [40][05][00][01][00][00][93][1B]
What I would expect to see is FF 00 right before the checksum, however all I ever see is 00 00.
I've attached my com trace and Lookout source.
Any help or suggestions would be greatly appreciated.
(5,675 Views)
OK, my problem seems to be timing.  We are using radio com links, so the cycle time is a bit slow.
Here's a simple question: how do tell Lookout (6.6)  to only write to a single coil.  Everything seems to want togle the bit (pushbutton, OneShot, etc.) all keep state and try to turn the coil OFF when the logic goes false.  The problem I have with this is the radio packet latency.  I want to just write to a coil and then check status.  Nothing more.  How can I do this?
Thanks in advance...
(5,662 Views)
You would need two seperate objects.
Create a connection on the modbus object and a switch:
MODBUS.10001 = CommandSwitch
Then create an expression:
MyExpression = MODBUS.10001
The switch tells the device what to do, the expression tells the operator what it is doing.
Is this close?
We have had problems with long-delay (serial radio) communications and the Remote connection.  This was our solution.  We also have additional logic (timers) that will reset the switch if the expression is not the same.
Forshock - Consult.Develop.Solve.
(5,650 Views)
