Lookout
Lookout won't print from File/Print/Alarms
My Lookout 6.0.2 package will do a print screen with no problem but won't print the Alarm/Event list from the file menu. Printer is OK.
(5,934 Views)
The Alarms and Events print option actually doesn't print to the printer.  Instead, it usually spits out a csv file in the Lookout directory (usually called journal.csv).  If you want to print alarms, you'll have to go the Options>System and then, in the upper right corner of the form, select LPT1 (or whatever your printer is on) in the Log alarms to box.  Does that help?
(5,931 Views)
