Lookout
MS OS Upgrade
I am attempting to upgrade Lookout version 6.0.2 from a MS Windows 2000 to a Windows XP. I copied my MS2000 database to the new machine and reinstalled Lookout but  I am unable to access my historical data. Any suggestions.
(3,628 Views)
Lookout 6.0.2 uses the Microsoft database for alarms only.  Historic data is still good old Citadel.  You will need to copy the database folder to the new machine.
(3,623 Views)
Duplicating a database on another machine will require a few additional steps beyond just copying the files, as the database needs to be properly registered with the system.  Depending on how you're planning on copying the data, there are two methods:
  • Across a network: Archive the database to another computer.
    1. Open Measurement & Automation Explorer (MAX)
    2. Right-Click on the database under Historical Data Viewer
    3. Select Archive...
    4. In the subsequent wizard you can choose databases and their archived location to any networked computer.
  • Using a storage device: If you are not going to a network computer
    1. In MAX, right-click the database and select "Detach/Delete..."
    2. Detach the database.
    3. Copy the whole database directory (located by default in Program Files>>National Instruments>>Lookout 6.0>>Database)
    4. On the new computer, go to MAX Historical Viewer
    5. Right-click on "My Computer,"
    6. Select "Create/Attach Database..."
    7. Browse and select from the data folder copied from the original comptuer.
Let me know if you run into any troubles!
Cheers,
Matt Pollock
(3,615 Views)
