Lookout
Is SQL Server needed?
Does the sql server engine have to be running for Lookout 6.0.2 to work properly or is just to query the database with NIMax? For security purposes, IT wants to block port 1433 which is for sql server if it is not needed to run Lookout properly.
Thanks!
Jason P.
Jason Phillips
(3,598 Views)
Hi Jason!
So I played around a bit and couldn't find any problems with stopping the SQL Server -- you just lose the ability to store and query alarms and events to/from the SQL database.  Alarms are stored in a temporary cache by Citadel until a new connection can be made with the SQL Server, so I'm not sure what long term consequences of this may be.
Doug M
For those unfamiliar with NBC's The Office, my icon is NOT a picture of me 🙂
(3,588 Views)
Thanks, Doug!
Jason Phillips
(3,585 Views)
