Lookout
.WMF file Help!
I am trying to load a process file onto a new run time computer.  The process file loads but the .wmf graphics don't show up.  Instead the "lost graphic" icon shows up.  What do I do to solve this problem?
(3,670 Views)
Lookout stores all the graphics in \National Instruments\Lookout 6.x\Graphics\, all the default graphics are installed with Lookout, but you maybe use some customized .wmf files in your process file.  So, you need to copy thoses .wmf files to the runtime computer, to the same folder.
Ryan Shi
(3,659 Views)
i usually make a separate folder for each lookout file and put all the graphics in that one folder....makes it easier to transfer or work on at home.....randy
(3,651 Views)
