Lookout
Make Formated Report
Hi my name is alejandro, i read some post, and they solve ma problem soso, but i need more help couse i need to make a report on a based format it seems to be like this below...
(3,846 Views)
Hi Alejandro:
I have replied to your posting on a separate thread. Please make sure to stick to one thread when you are posting a question as this makes it easier for people to respond as well as browse.
Could you give me a little more information about your application? What have you implemented thus far? What works and what doesnt? What object are you using in Lookout?
Jaideep
(3,822 Views)
Its an oven fot heat tratment, i want to implement lookout, couse i like the people see the proces in real time, before think in lookout i use a software from dataworx but its unfunctional, well what works and what not? i need to have the files in a file o data base dont care, i can sabe the info in fields but i want to do it on a tag and it must have a format like the one on the attachment, and the object that i am using is
My lookout version its 6.0
WEB Report. thanks i hope you can help me!
Mensaje editado por Oleta
(3,817 Views)
Hi Alejandro:
I still do not have a good feel for what the issue is exactly.
There is a report object in Lookout. I seem to think that you have tried using it. Did you encounter any errors? If so, can you let me know what they were?
Jaideep
(3,779 Views)
