Lookout
Why LOOKOUT 6.0 have "221 minutes remain before precess shut down"?
Hi,all
       I am use windows 2000 & LOOKOUT 6.0.I found the LOOKOUT 6.0 about dialog tell me a message.
"221 minutes remain before precess shut down".When i run it 221 minutes,LOOKOUT show me a dialog and quit.
Does anybody know this?
best regards!
guodaniu
(3,488 Views)
It sounds like you are using the integrator package. You can confirm this in the same dialog box. If so, it runs for 3 hours and shuts down.
(3,459 Views)
mjrx :
    Thank you for your reply!
    Does you mean the "integrator package" of lookout can only  run 3 hours?
   Have you any method  to solve this?
   And did you know which version of lookout have not this limit?
   The project made by this version can also only run  3 hours?
best regards!
                         guodaniu
帖子被guodaniu在12-08-2005 02:35 AM时编辑过了
(3,445 Views)
You have to find out what licensing you bought. If you purchased the integrator package, it will run only  3 hours at a time before shutting down, and this includes your process if you are running it on the same platform. You can develop the process and copy it and run it on another package, like another development or run-time only package. See:  https://www.ni.com/en/support/downloads/software-products/download.lookout-server.html
(3,439 Views)
