Lookout
NI-DNET
The NIDeviceNet Driver in Lookout 5.0 is for the NI DeviceNet card only?. Can I use this driver for other than NI manufacturer's card?
(3,764 Views)
This Lookout object is just installed when you have previously NI-DNET installed and obviously just works with NI-DNET cards.
Hope this helps
Roland
(3,764 Views)
So, if another card is used, this driver won't work. Is there any posibility to get a driver for another card?
(3,764 Views)
I doubt National Instruments is developing another DeviceNet card Lookout object. (it would not make much sense, right?)
However, if you want to develop your own Lookout object you can purchase the "Lookout Object Developers Toolkit" (P/N: 777325-01)
Check out the manual. Lookout Object Developer Toolkit Reference
Hope this helps
Roland
(3,764 Views)
