Lookout
Negative values on hypertrend
I'm using Lookout 6.5 and have a hypertrend with min/pos = -1500 and max/hgt = 4500 (See attached). When the value of my trend line is below 0, the line drops below the bottom of the trend. Any help with this issue is appreciated.
(5,862 Views)
I have 6.2 and tested negative values without issue.
Mike
Forshock - Consult.Develop.Solve.
(5,814 Views)
I had a similar problem with negative numbers and the only way I found to solve it was to either use a calculation to add a positive value equal to the most negative value of the input signal.  In your example you would add 1500 to the input signal value.  This would also increase the maximum value by the same amount.  This calculated value would be used only for the input to the HyperTrend graph.  Then insert a scale on the hypertrend graph showing the original (uncorrected) values with -1500 being the minimum.
This should allow you to keep all of your trace on the graph.
(5,633 Views)
