Lookout
On XP Machine dedicated to Lookout 6.5. The Hypertrends are not moving at proper pace according to the scale at the bottom of the trend graph. After 60 seconds it is 40 seconds behind, so the trace makes up the time with a straight line an repeats.
When you cut/copy a pot, and then paste it, lookout doesn't create a new pot, it just creates a new display for the same pot. So, if you modify one property, all will change because there is just one pot.
You can select a pot, press Ctrl, and drag it. A new pot will be created.
Ryan Shi
Message 11 of 11
(2,546 Views)
