Lookout
PDA & Lookout
Are there any options to connect Ipaq PDA running Windows mobile 6.0 or 5.0 and Lookout process running on desktop computer.
Desktop PC is also running OPC server if that helps.
Is it possible to run webserver on PC and then open process on PDA as web page. Before one needs to download activex controls from NI, are they executable on windows mobile platform?
(6,102 Views)
GAC_10,
I don't believe the ActiveX control will work for the Windows Mobile platform, but you may be able to use the report object to create a webpage that is readable using a PDA. This wouldn't have all the functionality but you would be able to monitor the process. Hope this helps!
Andy F.
(6,076 Views)
