Lookout
web server monitor mode not working as normal user
Hi everyone,
I have successfully been able to use the Web Server monitor mode (periodic snapshot) of a built application over a local network, but only have success when the application is running in the administrator profile.
When run as a restricted user, when I connect to the web page, it does not display any snapshot. The web page seems to be there, if I view the source it is as expected, just no image is displayed. Also, sometimes it does not connect properly (I dont know if this is symptomatic of the same problem or not).
Recap: under administrator everything works fine!
This must be some weird permissions/firewall thing, but I cannot figure it out.
Any ideas?
(5,835 Views)
nrp,
What version of Lookout are you using? Are you using the Report object to generate HTML? I believe you are correct that this is some sort of permissions thing, but it would help to have a little more information to figure this out. Thanks!
Andy F.
(5,816 Views)
