Lookout
PLC with NI Industrial Automation OPC server version 5.1
hello,
I am using NI Industrial Automation OPC server version 5.1. In that I have drivers for different companies PLCs & modbus which are inbuilt & given by NI.
But i want to add extra drivers for
1. Allen Bradley - Micrologix - ML1200
                                                ML1500
2. ABB - 07KR51
3. Mitsubishi - Fx-Series - FX1N
                                          FX2N
                                          FX3U
                     - Q-Series - Q00
                                       - Q01
                                       - Q02
Is it possible to do communication with above PLCs with NI Industrial Automation OPC server version 5.1?
Vijtin
(8,549 Views)
I'm sorry we don't have plan to update the IA OPC Server.
Recently we released NI OPC Server with DSC 8.5 and lookout 6.2. If you are using DSC 8.5 or higher, or lookout 6.2 or higher, NI OPC Server will be an option for you.
Here is a list of supported PLCs by NI OPC Server. Micrologix, FX and Q series are all supported.
http://zone.ni.com/devzone/cda/tut/p/id/6417
Take a look at this page, click on NI OPC Servers. You can download the evaluation software.
http://www.ni.com/opc
Note that the NI OPC Server can only work with DSC 8.5 or higher, and lookout 6.2 or higher.
Ryan Shi
(8,540 Views)
Technocrat Automation is a leading Industrial Automation
providing 100% Practical Training and Placement in all
leading brands of PLCs, SCADA, DCS, PAC, VFD, SERVO, MMI,
GSM PLC, Pneumatics and Field Instruments with State of Art
Technical Lab Facilities. plc training in chennai
ADVANCED PROCESS AUTOMATION TRAINING
DCS Plant Operation & Malfunction handling of below
mentioned Process Models:
* Distillation column
* Steam generator
* Steam Compressor
* Pump
* Heat exchange
* Flash drum
* Gas turbine
* Furnace
* Evaporator
* CSTR
* Plug flow reactor
* Fixed bed reactor
* Cogeneration boiler
----------------------------------------------------------------------------------------------------------------------www.bestplctraining.net
[url=http://www.bestplctraining.net//index.html/]plc training in chennai[/url]
[url=http://www.plctraininginchennai.com//]plc training in chennai[/url] / [url=http://www.plcscadatraining.net//]best plc training in chennai[/url]
Message 3 of 2
(3,274 Views)
Automation is a leading Industrial Automation providing 100% Practical Training and Placement in all leading brands of PLCs, SCADA, DCS, PAC, VFD, SERVO, MMI, GSM PLC, Pneumatics and Field Instruments with State of Art Technical Lab Facilities. plc training in chennai.
Message 4 of 2
(3,259 Views)
PLC Training In Chennai :
Technocrat Automation is a leading Industrial Automation providing 100% Practical Training and Placement in all leading brands of PLCs, SCADA, DCS, PAC, VFD, SERVO, MMI, GSM PLC, Pneumatics and Field Instruments with State of Art Technical Lab Facilities.
Distillation column
* Steam generator
* Steam Compressor
* Pump
* Heat exchange
* Flash drum
* Gas turbine
* Furnace
* Evaporator
* CSTR
* Plug flow reactor
* Fixed bed reactor
Message 5 of 2
(3,235 Views)
Technocrat Automation is a leading Industrial Automation providing 100% Practical Training and Placement in all leading brands of PLCs, SCADA, DCS, PAC, VFD, SERVO, MMI, GSM PLC, Pneumatics and Field Instruments with State of Art Technical Lab Facilities. plc training in chennai ADVANCED PROCESS AUTOMATION TRAINING DCS Plant Operation & Malfunction handling of below mentioned Process Models: * Distillation column * Steam generator * Steam Compressor * Pump * Heat exchange * Flash drum * Gas turbine * Furnace * Evaporator * CSTR * Plug flow reactor * Fixed bed reactor * Cogeneration boiler
www.plctraininginindia.com
Message 6 of 2
(3,213 Views)
Technocrat Automation is a leading Industrial Automation providing 100% Practical Training and Placement in all leading brands of PLCs, SCADA, DCS, PAC, VFD, SERVO, MMI, GSM PLC, Pneumatics and Field Instruments with State of Art Technical Lab Facilities. plc training in chennai ADVANCED PROCESS AUTOMATION TRAINING DCS Plant Operation & Malfunction handling of below mentioned Process Models: * Distillation column * Steam generator * Steam Compressor * Pump * Heat exchange * Flash drum * Gas turbine * Furnace * Evaporator * CSTR * Plug flow reactor * Fixed bed reactor * Cogeneration boiler.....................................
[url=http://www.industrialautomationtraining.com/]plc training in chennai[/url] | [url=http://www.processautomationtraining.net/]plc training in chennai[/url] | [url=http://www.technocratautomation.net/]plc training in madurai[/url] | [url=http://www.tiipa.com/]plc training chennai[/url] |
[url=http://www.seoindia4u.com/]SEO chennai[/url]
Message 7 of 2
(3,100 Views)
