Lookout
Pot values going to maximum value
I am running Lookout 6.1 on Win XP, and some of my pots are changing to their maximum value.
The pots are linked to the driver data member through a symbolic link.
Does anyone have an idea as to what would cause this to happen?
Our system is a telemetry system and the sites are polled every 1 - 2 minutes.
Jason Phillips
(5,806 Views)
Do you connect the remote source of the pot directly to the driver object address through the symbolic link?
You can take a look at the event in Alarm Windows. If it says that the pot value is changed at the remote source, it means the value in driver object changes.
Ryan Shi
(5,790 Views)
