Lookout
Problem with sending more than 1 pager alarm message
We have about 8 pager alarm objects created in our application. Each one is for a different alarm. When we test the system for the first alarm, the modem dials the pager and sends the alarm code. The problem we have is if we have a different alarm the modem does not call the pager. We have to restart Lookout after one alarm is sent before a second alarm is sent.
(4,886 Views)
Maybe it's because the previous pager occupies the port and modem always, and other pager can't access it.
Try to use only one pager for all 8 alarms.
Pager.send = alarm.update
Pager.message = alarm.message
If the phone number for 8 alarms are same,  pager.number =xxxx
If they are different, use alarm area to distinguish different alarms, and use an expression to get the different phone number, like
if(alarm.areaname=xxx, number1, if(.....))
Ryan Shi
(4,875 Views)
Ryan,
This is the first time that I have used Lookout so I am not sure what you want me to try. I am calling the same phone number and i am sending a different code based on what is in alarm - i.e. - 222, 333, 444.
By using 1 pager for all alarms it seems like the port will still stay busy.
Can you send me some screen shots showing how to configure the pager and alarm objects?
Example of alarms that i am trying to send:
Alarm Condition: Water level in tank is too low.    Send code to pager - 222
Alarm Condition: Motor not running.    Send code to pager - 555
(4,859 Views)
Is it a Numeric pager?
pager.number=xxxxx
pager.message= if(condition1, number1, if(condition2, number2, if(condition3, ...)))
pager.send=$alarm.update
Tell me how the outcome is.
Ryan Shi
(4,831 Views)
You should try U.C.ME-OPC from Control-See. See www.controlsee.com . You may download a trial version. U.C.ME may send alarms to pagers, cell phones(SMS), cell phones(voice), Email and Fax. You may also send SMS commands from your cell phone to Lookout to query or change tag value, or acknowledge an alarm.
Mike
(4,652 Views)
If you use an external program such as Control-See, what initiates the page from lookout?
Can you delay pages? For example, only send the alarm to the pager if the operator does not respond for 5 minutes.
(4,616 Views)
Alan,
U.C.ME-OPC connects to Lookout using OPC. Lookout is the OPC server while U.C.ME is an OPC client software. Once the alarm is triggered in Lookout, U.C.ME gets a messagge and initiates the alarm notification.
Yes, pages may be delayed. The administrator may define the recipients list and the timeout (in minutes) between each recipient. For more details please have a look at http://opc-sms.blogspot.com/ or at www.controlsee.com .
Mike
(4,606 Views)
