Lookout
Productivity 3000 modbus communication problem
The 0:00.001 is a valid setting. Lookout will try to poll the device at 0:00.001. But lookout is a windows application, not a real-time software running in real-time OS. Lookout cannot have this fast scan rate. It's not sure how fast it can be, because it depends on how complicated your lookout process is.
Ryan Shi
Message 11 of 16
(3,553 Views)
I have learned more about the failure mode of the Modbus communication.
I was so happy when I got a test program to work, however if I add another expression it kills the communication.
I found that if I put in an expression like Modbus1:300001 it works.
If I add Modbus1:300033 it kills the communication.
If I add Modbus1:300002 (which reads zero) the comm picks up again.
What is the syntax for double word in modbus?
Message 12 of 16
(3,482 Views)
The part where I said if I add Modbus1.300033, I have to add the second part Modbus1.300034 or communication will not work.
Message 13 of 16
(3,481 Views)
Try the D300033
Ryan Shi
Message 14 of 16
(3,475 Views)
Yes, that gives me an active number but I don't know what.
The 300001 (near zero), 300033 (near half scale) are counts from 0 to 65535
I suppose I can have data page that has all my my analog inputs thereby keeping the communication structure correct and alive.
Do you know the format this number represents;
Message 15 of 16
(3,470 Views)
The double word register is not a standard register in Modbus specification. Lookout combines two registers and get a DWORD value. The expression is
DWORD value = register1*65536 + register2
So, if 300033 is 1, and 300034 is 2, the D300033 will be 65538
You need to change the Numeric Format of the display on panel to get the exact number, instead of xxE+x
What kind of result do you expect for the DWORD register?
Ryan Shi
Message 16 of 16
(3,463 Views)
