Lookout
Remote ODBC Connection - Citadel
Hi
I have a citadel 4 database running on a PC (PC-A).  I wish to access the database from a different PC (PC-B) which has logos 4.5 installed but I am having difficulty getting the ODBC connection to work.  The situation is as follows:
Using PC-A, I can access the database using ODBC but cannot access PC-A's database from PC-B using UNC nor mapped drives.
If I copy the database from PC-A to PC-B and change the ODBC data source properties on PC-B to point to the local database then I can access it.
I have no problems in browsing or creating files in the directory on PC-A that hosts the database.
The error that is being thrown up on PC-B is as attached.  It would appear that the ODBC is fine as long as it's kept local and not over the network.
Any assistance would be greatly appreciated.
Message 1 of 1
(3,377 Views)
