Lookout
cable vs Leased Line which is better
Looking for info on what service would be better to use. I'm controlling 18 sewer pump station with radios now but want to make it faster and do some real times. At this point i'm polling each location once a minute and i want to see it in realtime.
(3,443 Views)
We have worked for two seperate customers where we installed ethernet modems on lease lines and connect to the remote PLC's using a Modbus driver and selecting Modbus ethernet mode and  have had good luck with that.  The poll rates we have set are between 1 to 3 secs.  The server on one site currently is looking at 9 sites.
We had some situations where the lease lines were being abandoned so we have now switch most of the sites to wireless ethernet radios and are having excellent results.
We have not tried cable but using the radios and ethernet have worked well.  Previous to the conversion to ethernet modems we were using serial modems.  With the serial modems we needed to transfer all the data to a master PLC and then have Lookout Poll the master PLC.  The poll times there were longer due to the nature of the polling updates.
Mike
(3,349 Views)
