Lookout
The latest Lookout fix patch causes an error.
I applied the latest fix patch for Lookout 4.5.1 dated 3/8/2002. It now causes this error when I attempt to open my program: "Cbl has caused an error in ALLBRAD.CBX. Cbl will now close." If I restore the original ALLBRAB.CBX the problem does not occur. Any ideas?
(3,142 Views)
I guess accidently we changed something which does not well behave with compilation.
We could reproduce the issue and will update the CBX as soon as possible. For now you might just use the shipping version.
I should post a new message when we put up the fixed allbrad.cbx.
Regards
Roland
(3,142 Views)
We just currently put up the fixed ALLBRAD.CBX - check it out!
www.ni.com/support > Drivers and Updates > Search Drivers and Updates > type 'Lookout 5' and you should get the link for 'Lookout 5.0 for Windows -- Fixes'
Hope this helps
Roland
PS: You should be able to use the driver CBX version 5.0 in Lookout 4.5.1. Or you might consider to upgrade to Lookout 5.0. www.ni.com/lookout.
(3,142 Views)
