Lookout
Would Lookout support Honeywell UDC 3000 and PMA KS-94 temperature controllers
Informartion is to be sent via RS 232/RS-422
(3,177 Views)
Lookout has a ASCII object. You can send and receive regular strings/commands through a COM port. Therefore, I could imagine that you might communicate with your devices.
If your devices would support some common protocol you might use a specific driver (e.g. modbus, profibus).
There is a general posted message about using the ASCII object on this forum, which might help, too: http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=5065000000080000006E370000&UCATEGORY_0=_9_&UCATEGORY_S=0
Hope this helps
Roland
(3,177 Views)
_______________________________________
Using the ASCII Object as mentioned by Roli-Poli would be one option, especially if the protocol is a simple one. Another option is to use OPC Server. A quick search on the Net gave the following results for 3rd party OPC Servers for Honeywell UDC 3000:
http://www.kepware.com/Honeywell_UDC_OPC_ServerSpecSheet.html
http://www.softwaretoolbox.com/store/ShowTOPServerDemoContents.asp
Hope this helps.
Khalid 🙂
(3,177 Views)
