Typically, when you look at a gauge, there is a small red band and the rest is the "acceptable" region. Examples of this are your speedometer and tachometer in your car.
However, there are others that have both a high and low red band. Examples of this are your voltage meter and oil level/temp gauges.
In LawView, I only see gauges/meters with one red band.
I need a gauge that goes like this:
Range: 0.750 to 1.250
Redline A: 0.750 to 0.959
Redline B: 1.041 to 1.250
I just want the operator to look at the gauge and quickly be able to determine if the pieces are passing or failing. The test requries a ratio of 1.000 +- 4% of a reference piece. (that's where I get the numbers from)
Is this possible?
