Lookout
modbus ethernet
hello sirs
i am using modbus object in ethernet mode. i am getting error as a SOCKET TIME OUT. So how will i get communication using modbus object in ethernet mode?
vijeta
(4,397 Views)
Which software are you using?
Here is a software that you can use to do a test.
If it can't communicate with devices either, I think it's the modbus slave's problem.
Ryan Shi
(4,386 Views)
