Lookout
Using Win 911 with Lookout 6.1
I am trying to get Win911 to communiucate with Lookout 6.1 via OPC.
Is this still true in 6.1,
How Do I Use Lookout as an OPC Server?
Primary Software: Lookout
Primary Software Version: 5.0
Primary Software Fixed Version: N/A
Secondary Software:
Problem: How do I use Lookout as an OPC Server?
Solution: Lookout has an OPC Server called National Instruments.LookoutOPCServer. Lookout automatically serves up all of the data members of every object in any Lookout process that is currently running.
In order to view the items from an OPC client, the Lookout process must first be running.
Any tips on how to set up the connection between Lookout and Win911 would be greatly appreciated.
Thanks!
Jason Phillips
Message 1 of 1
(4,094 Views)
