Lookout
Upgrade issues from Lookout 6.0 to 6.5
Can someone help me with step by step upgrade of application from lookout 6.0 to 6.5 . I am specifically intrested in database conversion steps as I am having problem with accesing lookout databse from WIN911 alarming software.
(5,572 Views)
Both 6.0 and 6.5 use the Citadel 5 database. There is no compatibility issue. Actually, when you upgrade lookout from 6.0 to 6.5, you don't need to convert the database. Just use it directly.
So I guess your problem is somewhere else, such as configuration.
Ryan Shi
(5,552 Views)
