Lookout
Using "Choose" Statment in Lookout
To simplify, I have 3 POTS.  I want to select the value of (1) of the three pots in an expression (using a radio type switch).   When I use the expression CHOOSE.  The values do not show up.I have tried NCHOOSE and LCHOOSE also....
(3,429 Views)
you will need a fourth pot that you set to 1 2 or 3 and use nchoose function... something like this works.. nchoose(Pot4,Pot1,Pot2,Pot3)
(3,422 Views)
Max.... is right.  And if you want to use the Radio Object, you would just use it in place of Pot4, like this:  nchoose(Radio1,Pot1,Pot2,Pot3)
-Khalid
(3,418 Views)
