Home
Community
Discussion Forums
Special Interest Boards
Lookout
Topic
Lookout
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Using "Choose" Statment in Lookout
haroldc_gtmc@sb
cglobal.net
Member
12-03-2006
01:02 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
To simplify, I have 3 POTS. I want to select the value of (1) of the three pots in an expression (using a radio type switch). When I use the expression CHOOSE. The values do not show up.I have tried NCHOOSE and LCHOOSE also....
0
Kudos
Message
1
of 3
(3,529 Views)
Reply
Re: Using "Choose" Statment in Lookout
maxofmillions
Member
12-03-2006
09:34 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
you will need a fourth pot that you set to 1 2 or 3 and use nchoose function... something like this works.. nchoose(Pot4,Pot1,Pot2,Pot3)
0
Kudos
Message
2
of 3
(3,522 Views)
Reply
Khalid
Active Participant
12-03-2006
10:43 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Max.... is right. And if you want to use the Radio Object, you would just use it in place of Pot4, like this: nchoose(Radio1,Pot1,Pot2,Pot3)
-Khalid
0
Kudos
Message
3
of 3
(3,518 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
