Lookout
Vibration alarm level as a function of RPM
I am working on the vibration panel for a machine with variable speed. The vibration alarm levels should be a function of the operating speed.
Data Member Configuration screen accepts only constant values in the Alarm Condition box, HiHi, Lo, LoLo.  Is there a way to use a conditional alarm levels?
(3,220 Views)
You might consider using digital alarms and an expression, where the expression is evaluated with speed and vibration level, and the digital is true if in alarm.  Your alarm message and description then could publish the speed and alarm level to indicate the values, though it is a digital.
Hope this helps.
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(3,218 Views)
You could also use the Alarm object where the HiHi, LoLo, etc., can be variables/signals (yellow fields).
-Khalid
(3,191 Views)
