Lookout
Lookout Profibus Driver support replacement for SST-5136-PFB
The manufacture no longer makes the S-S Technologies card 5136-PFB PC card, but have replaced it with the SST-PFB3-PCI card (see http://www.mysst.com/cards/profibus/pfbpci.asp). Has anyone successfully used this newer card with the Lookout Profibus DP Driver? If not, has anyone found a reliable OPC Profibus DP driver?
John T. Sampson
(3,898 Views)
When ordering the SST-PFB3-PCI you also need to order SST-PB3-OPC to get the OPC server for this card. You can also communicate with the card via DLL calls to PFBMAN32.DLL.
(3,740 Views)
