Lookout
We currently have Lookout 6.0 connected to an AB SLC 5/05 via ethernet. I want to change the IP address of the SLC. Where, in Lookout, do I change the IP address it looks to find the SLC.
I need to change the IP address of the SLC 5/05 and when I do Lookout 6.0 can't find it.  Where, in Lookout, do I set the IP address?
(3,427 Views)
Go into edit mode. In object explorer, right click the SLC5/05 object and select properties. You can see the IP address.
Ryan Shi
(3,418 Views)
