Lookout
What does the error "Could not load class!" mean?
I've just loaded Lookout 6.1 on a new computer and have tried to load a process file onto it.  I'm getting the error messages: "Could not load class!" and "Error running process file!" I can take the same process file and load it onto a different computer with no problems.  What should I look for?
Message 1 of 9
(9,176 Views)
Does your process use either a custom or third party object that is not installed?  I have gotten this error when loading a process that uses the Direct Logic Plus driver object when I failed to install Direct Logic Plus into the correct folder.
Message 2 of 9
(9,170 Views)
what is the correct directory i put it in the c:\programfiles\nationalintruments\lookout 6.1\dscomm4.cbx and when I go into the process file it still gives me the could not load class error?
Message 3 of 9
(8,348 Views)
Delete the lookout.dat file and reopen lookout.
Ryan Shi
Message 4 of 9
(8,333 Views)
I'm having the same problem, new install on Win7 Lookout 6.6. Deleted Lookout.dat, same error. Verified DirectLogicPlus is in the folder, reloaded a couple of times. Any help would be appriciated.
Message 5 of 9
(7,681 Views)
I didnt think the DLPlus driver was updated for Windows 7 and Lookout 6?
http://www.hosteng.com/
Forshock - Consult.Develop.Solve.
Message 6 of 9
(7,652 Views)
If you are using development server, try to create a new process and create new object, do you see the DirectLogic driver in driver list?
Ryan Shi
Message 7 of 9
(7,646 Views)
The server is running on another machine (windows XP). I am doing a new client install on a windows 7 machine. Yes, the Directlogic driver is in the list on that machine, and other clients (windows XP) are working with it.
Message 8 of 9
(7,635 Views)
The direct logic driver WILL NOT work with Windows 7, and Automation Direct says they are not upgrading the driver to work with windows 7 Smiley Frustrated.
We are in the process of moving to NIOPC Servers for our DirectLogic PLCs. So far, the move has been going well.
Jason Phillips
Message 9 of 9
(7,602 Views)
