Lookout
beeps for alarms
Dear all
I have a problem in lookout v6.0, for all alarms that I create only 7 beep appears and then beeps become silent
What is problem?
Thanks in advance
M.J.Danesh
(3,808 Views)
Accepted by Danesh
Danesh,
The reason you have 7 beeps for every alarm is due to the setting you have in the lookout.ini file. This file stores the configurations of lookout. You can open this file with any text editor and change the number of beeps you want whenever any alarm is generated. Go to the line with the following text and specify the number of times you want the alarm to beep.
Audible
=0 Give no audible notification of alarms.
=1 Give audible notification (beep!) of alarms. (default)
Ame G.
(3,778 Views)
Very thanks for your answer
i find that line in lookout.ini file and the audiable=1 but number of beeps is 7 times yet,
when can i set number of beeps to unlimited?
M.J.Danesh
(3,769 Views)
