Lookout
citadel file corruption
It appears as if my citadel database file may be corrupted. I received a Logos error, shutting down logos and the citadel logging service. When I move my logging area to a different folder, it works again. however, if I try to connect to the old database through Lookout, MAX, or through an MSQuery, I get the same error. I tried installing the new Logos 4.5, but there was an error here too which aborted the installation (there was a file that did not appear in my Temp folder). I then tried going through the other steps in the 'Can I fix a corrupted database in lookout 4?' and after removing the .mdx and .tdx files, and trying to reopen lookout, it did not regenerate these files. I tried the other steps, but always came up with the same error. Is
there anything else I can do to retrieve the data stored in the database?
(3,294 Views)
This link might help,
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/6fc62f75b74d706d8625694900768f69?OpenDocument
Also, I would suggest backing up your database at least twice a day. This link includes a process file that will do that:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3E22756A4E034080020E74861&p_node=DZ52189&p_source=external
Good Luck!
Jason Phillips
(3,294 Views)
