Lookout
confirmation box
I'm using two monitors for my SCADA application. Is there a way to change the position where confirmation box popups so it don't be divided in two monitors?
(6,530 Views)
Is one monitor set up as "extended" monitor? Or two monitors have exactly the same display?
I guess you just have two monitors show exactly the same thing. If so, the pop-up box will be on both monitor, and it cannot be changed.
Ryan Shi
(6,484 Views)
No, we are using one monitor as extended, so there are a different screens on those monitors and we can move the windows from one monitor to another.
Ivan K.
(6,482 Views)
Accepted by iwanhoo
The position of confirmation box cannot be customized.
Ryan Shi
(6,458 Views)
Thank you.
Ivan K.
(6,446 Views)
