Lookout
excel resolution
Hi there
My problem is whit excel, i have a program in labview 6.1 that read a strain gage signal
when i open the data in excel (  time vs volts)  excel only put  3 decimal cifers and i am loosing resolution
i found a temporal solution that is multiply 1000 times the signal
can you give me an alternative solution?
another thing is happening,  when i put my sample rate at 0.1ms ( 10.000 samples/s) and the number of samples at 10000,
 in real time my program should adquire data in 1s , but that is not happening , this procces is taking  too much time.
can you explain what is happening?
thanks,
Juliana
(6,224 Views)
Can you elaborate on the following points -
1. Which is the version of MS Office (Excel) ?
2. Is it possible to send a sample VI or screen print of the part where the data is being written in the file ?
3. What is the actual value being read in the excel sheet & what should be the actual value ? (Give example)
Ravinder
(5,993 Views)
