Lookout
lookout and NI 485
System: windows XP sp2
Machine: Brown T345V
We would like to update old serial NI-485 ISA card with another PCI card.
Questions:
1- As I've understood, Lookout NEEDS NI-485 to work properly, and not another brand of card. Is it correct?
2- If point #1 is correct, then what model of National PCI card should we use to make Lookout work properly?
(6,290 Views)
We didn't test any 3rd party PCI-485 card with Lookout. But actually I think it doesn't matter which card you use. Lookout just sends data and receives data through the COM port. It doesn't know and doesn't care if it is a built-in port or a PCI card. Lookout doesn't talks to the card directly. So, I suggest you to use NI PCI-485 card, but I don't think other 3rd party card will not work.
Ryan Shi
(6,286 Views)
Thank you for answering me. This morning I'm going to test the machine and wi keep this forum updated.
Best regards
(6,283 Views)
