Lookout
vista
Dear All,
I can not run Lookout v 6.1 under Vista Os on Vaio notebook.
Help me please
Message 1 of 11
(9,224 Views)
What error do you get? Can you install it?
Is the Vista 32bit or 64bit? CPU 32bit or 64bit?
Ryan Shi
Message 2 of 11
(9,208 Views)
32 Bit Oprating system
Intel cour duo cpu  T930 @ 2.5 GHz
Yes Lookout Is installed but not running at all and no error apear
Message Edited by danesh on 07-18-2008 01:54 AM
Message 3 of 11
(9,202 Views)
Do you install and run it as the Administrator of Vista?
What do you see after you double click the lookout.exe? Is the lookout.exe running in Task Manager?
I don't want to suggest the reinstall, but you can try it.
Ryan Shi
Message 4 of 11
(9,198 Views)
I reinstall it but the problem not solved.
Message 5 of 11
(9,169 Views)
Open Task Manager, check if NICitadel5Service, lkClassAds and lkTimeSync are running.
Run Lookout.exe, check if lookout.exe is running.
Open Control Panel->Event Viewer, see if any error or warning about Lookout or Citadel logged in Windows Logs->Application.
Ryan Shi
Message 6 of 11
(9,165 Views)
no things apear in service or process !!!
Message 7 of 11
(9,058 Views)
So, the required services are not running. Go to Control Panel(Classic View)->Administrative Tools->Services.  Check if the services are installed, including NI Citadel, NI PSP Server Locator, NI Time Synchronization, NI Service Locator. If you can see them, but not running, right click on it and select Start. But if you cannot see them, the install of Lookout might have something wrong. Did you see errors during the install? Did you install the Lookout as Administrator?
With these services running, try again to launch lookout.exe.
Ryan Shi
Message 8 of 11
(9,042 Views)
I do all of this and all services is running but lookout not run, also i reinstall lookout but no change!
what is your solution?
Message 9 of 11
(8,837 Views)
Ryan Shi
Message 10 of 11
(8,833 Views)
