Lookout
export hypertrend from lookout version 5 to 6
hallo...
i work with lookout version nr.5 and i have to pass to version nr.6...
if i start my program with lookout nr.6 i miss the old trend...
i explain better: i would like to read the trend written with lookout nr.5 with the lookout nr.6... how can i do?
thankyou very much
Roberto Passoni
(5,857 Views)
Lookout 5 uses Citadel 4 database, which can not be viewed by Lookout 6. You need first to convert the Citadel 4 database into Citadel 5 database, and then archive to the current using database.
Follow this KB first to convert.
After this, you will get a Citadel 5 database with the old data. You need to archive it to the current one in order to merge the old data with the new data. Follow this KB to archive.
Ryan Shi
(5,842 Views)
