Lookout
How do I disable Modbus Ascii in my ini file.
I need to disable the Modbus ASCII protocol in my Modbus polling. How do I do this in Lookout 6.0?
(6,856 Views)
See this KB.
To only use RTU,
Protocol=RTU
Ryan Shi
(6,847 Views)
Where is the ini file located? I did a search for it and did not find it.
(6,842 Views)
You need to create modbus.ini by yourself.
Ryan Shi
(6,833 Views)
So once I create the file, where do I need to store it so that I can use it?
(6,831 Views)
Sorry I didn't say clearly enough about this file.
Just create the modbus.ini, and put it in Lookout folder.
Ryan Shi
(6,827 Views)
